2D Drafting
Positioning objects accurately
In ViaCad 2d/3d how do you precisely locate objects on a drawing? For example: I draw a rectangle that will be a mounting plate. Simple enough. Now I want to place a hole with a center 4 mm from the top edge of the plate and 4mm from the side of the plate. How do you do this? Thanks
hi, here is one possible way:
create construction lines (see pictures)
Edited by user Saturday, November 5, 2016 6:35:40 AM(UTC)
(72kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
2D Drafting
