la mouche
#1 Posted : Wednesday, December 4, 2013 8:07:48 AM(UTC)
la mouche
Tim?
why SharkFX v.8 crash often with models about 100MB with Phong display?
But never with wireframe?
I said that I worked super fine setting.
Here are my settings. Thank you to tell me if you see something incoherent or could help me.
Thank you.
Antoine
Capture d™©cran 2013-12-04 15.12.20.png (67kb) downloaded 0 time(s).
#2 Posted : Wednesday, December 4, 2013 4:06:47 PM(UTC)
It could be you are running out of memory. The facet display list can take up a bunch of memory,especially if you are using super fine.
You can see if this is the case by looking at the activity monitor. Look at the Shark process thread and see if the Real Mem is greater then 2.3 GB. If so, you are likely running of memory for a 32 bit app.
