17b
#1 Posted : Monday, October 10, 2016 1:15:05 PM(UTC)
17b
i purchased a ViaCAD 9 pro Version last Year and worked with it several Months without Problems.
Now i had to install it again because i had to reinstall my complete computer. First i got a "Fingerprint mismatch" Error after installing it. The german "Support" told me to delete the Program using a Third Party Software called "Revo", download a trial Version from the official Downloadpage and reinstall the Program. I did as i was told and got a message, that the Program can not be activated because there are no current Activations. I sent a screenshot to the "Support" Team and got as solution for my problem the same answer as the day before, i shall download a trial Version from the Downloadpage.
I can hardly understand why it is impossible to install this Program. The Hardware didnt changed since i purchased the key and it worked till now.
I havent got an answer since Thursday from the german "Support" and i am really pi..ed. I cant use the Program since several Weeks. This is not a cracked Version nor do i have a stolen Key.
Does anybody have a solution for me?
Stefan
17b attached the following image(s):
horst.w
#2 Posted : Monday, October 10, 2016 2:38:59 PM(UTC)
horst.w
Welche Version hast Du?
Die ausgelieferte Version vom Sommer / Herbst 2015 hat sich nicht installieren lassen, ich hatte von Avanquest einen neuen Download-Link bekommen, dann funktionierte alles.
ViaCADPro9_DE.exe
oder
ViaCADPro9_1166_ESD_DE_YDRM.exe
Horst
Kundenkonto hast Du? -siehe Bild -
Edited by user Monday, October 10, 2016 2:49:25 PM(UTC)  | Reason: attach pic
17b
#3 Posted : Monday, October 10, 2016 3:46:40 PM(UTC)
17b
Ich habe die genommen, die mir Avanquest selbst vorgeschlagen hat:
http://www.viacadsoftware.de/jetzt-kaufen/
Dann die Version unter "jetzt testen". Es ist die "ViaCADPro9_1181_YDRM_AMZ_DE". Ich hatte auch noch ne ältere Version ausprobiert die definitiv beim letzten Mal lief. Funktioniert aber auch nicht mehr mit meinem Key. Den Key spiele ich immer mit copy/paste aus der Originalmail ein, also auch keinen Vertipper.
Ich finde es sehr nervig immer nur mit vorgefertigten Mails abgespeist zu werden. Bei Freeware mag das ja sein, aber nicht wenn man die Software original gekauft hat. Und wenn sich dann der "Support" garnicht mehr meldet ist das nur noch eine Frecheit.
Kundenkonto hab ich natürlich.
Gruß
Stefan
Edited by user Monday, October 10, 2016 3:47:54 PM(UTC)  | Reason: Not specified
horst.w
#4 Posted : Tuesday, October 11, 2016 11:02:28 AM(UTC)
horst.w
... dann habe ich nur noch 1 Idee:
Die EXE.-Datei nicht mit Doppelklick starten, sondern rechte Mousetaste und "Starten als Administrator" wählen, auch wenn es (wie bei mir) nur einen Nutzer gibt, der eigentlich automatisch Admin sein sollte. Das hatte auch schon geholfen.
Good luck!
Horst
17b
#5 Posted : Tuesday, October 11, 2016 2:04:24 PM(UTC)
17b
Das war auch eine der Vorgaben seitens des tollen "Supports". Bringt nichts. Vielleicht sollte ich mich mal direkt an Tim Olson wenden.
#6 Posted : Tuesday, October 11, 2016 2:22:14 PM(UTC)
Hi Stefan
The DRM monitors the number of installs. It sounds like it triggered a flag for number of installs. I do not have access to the DRM, as Encore adds it to the product. I would suggest contacting Encore support. This will get you to Todd who should be able to fix this issue for you. I'll forward him your post and email address as well.
http://support.encore.co...frm.aspx?product_id=2820
Edited by user Tuesday, October 11, 2016 2:23:08 PM(UTC)  | Reason: Not specified
17b
#7 Posted : Tuesday, October 11, 2016 6:41:43 PM(UTC)
17b
Hi Tim,
thanks for your fast answer.
I mailed my problem to Todd, hope he can help me.
Best Regards
Stefan
#8 Posted : Tuesday, October 11, 2016 8:24:39 PM(UTC)
Todd said he's on the lookout for the support ticket.
