My pictures are very pixelated. How can I change this? Thus the renderings are not to be used.
Originally Posted by: macyone My pictures are very pixelated. How can I change this? Thus the renderings are not to be used.
PhotoRender uses the display resolution.
1. The Edit : Change Resolution : Super Fine : Precise Facets command will give you the highest resolution using defaults.
2. Prefs : Custom Resolution allows you to override the resolution settings for Fine, Medium, Super Fine etc
3. Edit : Change Object Type : Mesh, set facet parameters, then cancel. Be sure to cancel. When you cancel, the mesh is applied as the display list of the surface/solid. This gives you complete control of the display faceting.
I'll see if I can add this to the v10 tips book with some descriptive images.
Edited by user Tuesday, October 11, 2016 2:48:33 PM(UTC)
Hi Tim, Unfortunately I can not follow your instructions. I have a German version I can not start with the info. Can you post me a few Screeshots. Basically, the resolution must be adjusted when rendering! Or is it only in international not possible?
Select the object you want to increase resolution and then pick the Edit : Change Resolution command and set to SuperFine and Precise.
(140kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
