Thanks: 22 times Was thanked: 8 time(s) in 8 post(s)
                Hi I am using the v 10 beta. I have a model that renders great when I photorender it.  But when I render to file it looks terrible.  I noticed that VIacad keeps a copy of the last rendered image-  but where does it keep that and how can I use it versus render to file?
Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
                jbskaggs,
I don't know how much help I can be since I don't have time to beta-test v10, nor do I have it loaded on my computer. However, I'm wondering if it makes any difference what kind of file you save it as (e.g. .jpg, .bmp, .tga, etc.)? What are the render settings? Could you post a small sample of what the bad render-to-file looks like?
My apologies if you have already thought of (or tried) the items above...
Tim (NOT Tim O.)
Edited by user  Saturday, October 1, 2016 6:00:40 PM(UTC)
 | Reason: Not specified
    Tim (NOT Tim Olson) ViaCAD 2D/3D and PRO V9 1184, Blender 2.49-2.78. Win 7 SP1, Core I5, 64-bit, NVIDIA G105M
                It seems saving as jpg and having "use antialias feature following" selected in render settings made a big deal.
                The .jpg format is compressed and quality can be noticeably affected. I would also try .bmp or the other available formats where file size is larger, but you don't lose as much quality from compression. I notice that ViaCAD does not allow you to set the amount of compression for .jpg (at least I don't see any options to do so). My v9 of ViaCAD Pro does, however, render to file just fine even using .jpg. Antialias can indeed make a huge difference, as you already mentioned. Anyway, is your problem solved?
EDIT UPDATE: I just rendered some objects to file in .jpg format using ViaCAD Pro v9 Build 1184. The render settings were "Raytrace (shadows,anti-alias"), but with "Anti-Alias Feature Following" turned OFF (i.e. NOT checked). My .jpg image looks fine.
So maybe you really have found a bug in the v10 beta? A small sample image may still help...
Tim (not Tim O.)
Edited by user  Sunday, October 2, 2016 9:47:40 AM(UTC)
 | Reason: Update with added information.
