Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hello Tim,
Can you explain how to use the function: symmetry in mesh mode?
For me i can not use this feature.
Thank you.
Antoine
Antoine attached the following image(s):
(60kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Antoine ???
Video :
Mesh Symmetry I've got videos for most of the new v10 tools at:
V10 New Features Tim
Thank you Tim! 1. Could you implement this function in version of SharkFX 1162FR or 1210US? Because this function is currently incomplete in these versions. 2. Could you add a function to reset the plane of symmetry, as if orienting the plane of symmetry at an angle, it is impossible to realign in the x, y, z after. Thank you Antoine
>>Could you implement this function in version of SharkFX 1162FR or 1210US? No sorry, it uses the new infinite plane display features of v10. >>Could you add a function to reset the plane of symmetry, as if orienting the plane of symmetry at an angle, it is impossible to realign in the x, y, z after. Yes good idea. Perhaps right click on the plane and in the popup menu it has plane orientation options? Or are you thinking something else? Tim
Hello Tim, The best would be minimum a reset. And also a storage customized plans and the ability to activate depending on the menu popup. Thank you Antoine
