Thanks: 47 times Was thanked: 73 time(s) in 53 post(s)
Hi, Anybody else getting this.... Registration Error You have reached the limit of authorizations available for this serial number. Cheers Mike
Hi Mike Can you try again, I activated the serial number for more installs. Tim
Thanks Tim,
I got a bounce back from
techsupport@punchcad.com , so I popped this post up.
I've tried it again, and got an authorisation code thank you, but still says trial version days left = 15
I will delete the older beta versions of SharkFX and see if this clears things up.
Mike
Deleting the old betas, gave a blank registration field, so I added the data, "Register Now' to generate an "Authorisation Code", but pasting it in, and hitting "Activate" just leaves the Trial Version Days Left =15 showing Mike
