24c
#1 Posted : Monday, September 12, 2016 1:24:57 PM(UTC)
24c
Was thanked: 67 time(s) in 49 post(s)
Anybody else getting this....
Registration Error
You have reached the limit of authorizations available for this serial number.
Cheers
Mike
macOS Tahoe - v16 beta
#2 Posted : Monday, September 12, 2016 1:43:00 PM(UTC)
Hi Mike
Can you try again, I activated the serial number for more installs.
24c
#3 Posted : Monday, September 12, 2016 2:14:33 PM(UTC)
24c
Thanks Tim,
I got a bounce back from techsupport@punchcad.com, so I popped this post up.
I've tried it again, and got an authorisation code thank you, but still says trial version days left = 15
I will delete the older beta versions of SharkFX and see if this clears things up.
Mike
24c
#4 Posted : Monday, September 12, 2016 2:26:51 PM(UTC)
24c
Deleting the old betas, gave a blank registration field, so I added the data, "Register Now' to generate an "Authorisation Code", but pasting it in, and hitting "Activate" just leaves the Trial Version Days Left =15 showing
Mike
