horst.w
#1 Posted : Monday, September 5, 2016 10:11:16 AM(UTC)
horst.w
Hi at all,
I'm using ViaCad 9 Prof German Version.
When I store an object all historie is lost when reopen it next time.
In <Presetting> the box "Delete GoBack when store" is NOT checked on - the picture shows it only to demonstrate what I mean.
But I tried also "checked on" because the translation of this menue-point may be fault. No difference, the GoBack-historie ist not stored when I close the window - checked or unchecked.
What is going wrong there?
Greetings Horst, GER
[img=UserPostedImage]PreSettings[/img]
#2 Posted : Tuesday, September 6, 2016 12:41:57 PM(UTC)
Hello Horst
Yes, I can confirm here that the undo stack gets clears when the program closes on V9, no matter what settings are picked in preferences.
horst.w
#3 Posted : Tuesday, September 6, 2016 2:31:30 PM(UTC)
horst.w
Thanks for the information.
Horst
#4 Posted : Tuesday, September 6, 2016 2:44:31 PM(UTC)
The setting in the preferences I believe its intent is just to clear the undo stack or not when a save is done while working on a file. When you close a file and reopen the undo stack is cleared.
