Bob La Londe
#1 Posted : Friday, August 5, 2016 12:12:49 PM(UTC)
Bob La Londe
I downloaded the PowerPack file yesterday and installed it on my computer. Its about 366KB, and all that seem to happen was that it installed a folder containing an .ini file in the Program Data folder. Nothing else seems to have changed. The ini file is 144KB. That seems about right when you compare file sizes and add the overhead for the .exe extractor.
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
#2 Posted : Friday, August 5, 2016 12:56:29 PM(UTC)
Hi Bob
The PowerPack installer just installs a license on your machine. When the app launches, it looks for the license file and turns on additional features.
Bob La Londe
#3 Posted : Friday, August 5, 2016 1:04:04 PM(UTC)
Bob La Londe
Hi Bob
At the risk of sounding stupid... where do I find these new features? Nothing seems to have shown up in the menus on VC. My 32bit box is running the latest 32bit build according to the menu link.
P.S. yes I did move the Punch! folder up one level to the programdata folder.
Edited by user Friday, August 5, 2016 1:07:01 PM(UTC)  | Reason: Not specified
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
Kartoffel
#4 Posted : Friday, August 5, 2016 1:16:36 PM(UTC)
Kartoffel
Hello Bob,
it adds "powerpack" in the menu-bar.
Perhaps a restart helps?
Markus
Bob La Londe
#5 Posted : Friday, August 5, 2016 1:26:15 PM(UTC)
Bob La Londe
Originally Posted by: Kartoffel Go to Quoted Post
Hello Bob,
Markus
Yep. A restart is what I expected, but its been restarted several times over last day or so. I also moved the Punch! folder per other conversations. Nothing appears.
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
#6 Posted : Friday, August 5, 2016 1:33:51 PM(UTC)
Attached image shows powerpack.
Bob La Londe
#7 Posted : Friday, August 5, 2016 1:35:13 PM(UTC)
Bob La Londe
Ok, figured it out. The location stated didn't work. I had to place the PowerPakc Folder in the Punch! folder inside the hidden application data folder under all users. Now the PowerPack Menu item appears.
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
digital
#8 Posted : Monday, October 24, 2016 11:18:00 AM(UTC)
digital
I can confirm the issue as well, thank you Bob La Londe
the full path where the .PowerPack10.ini is installed is:
C:\ProgramData\Application Data\Punch!\PowerPack
and it should be:
C:\ProgramData\Punch!\PowerPack
After doing this and restarting ViaCad Pro 10 the extra menu is there.
There is no option in the installer to change the path manually.
I'm using Windows 10
