Dr. Tomazic Gerd
#1 Posted : Monday, July 25, 2016 6:32:31 AM(UTC)
Dr. Tomazic Gerd
Austria
In several tutorials I can see in the prompt window a button for context sensitive help. I do not have this button. Neither in Via Cad 9 pro, nor in Via Cad 9 pro. Is there a way to switch this special help on?
#2 Posted : Monday, July 25, 2016 12:22:05 PM(UTC)
You will see the ? in the data entry window if HTML help is available. Not all localizations and tools have created HTML files. Do you see it for the Opposite Point Circle Tool?
Edited by user Monday, July 25, 2016 12:26:35 PM(UTC)  | Reason: Not specified
Kartoffel
#3 Posted : Monday, July 25, 2016 2:04:07 PM(UTC)
Kartoffel
Was thanked: 5 time(s) in 5 post(s)
I also have no ? f.e. with the opposite circle tool. Perhaps it is the german language version I use, where no such help is available?
Markus
