First, sorry for all the post lately. I'm finding most of my answers from searches or the tutorials. This one I can't find to save my life.
If you look at the attached pic, you will notice that I created a simple box. It is 3.5" x 10.25" I then opened the attribute/BOM panel, and clicked "apply to selected" for the cutlist properties option. you will first notice that in the appropriate areas on the attribute/BOM panel, it says my box is 3" x 10" and then the BOM lists it out the same. However, the other panels say it is 3.5" x 10.25" as I created it. For some reason, BOM wants to round down. Not good for cut files as then they will be short. I checked all settings I can think of. Even uninstalled the app and reinstalled.
What am I over looking?
There was a rounding issue that was corrected in a later build. What build are you using?
From the build notes, I think around 1193.
http://forum.punchcad.com/default.aspx?g=posts&t=7757#post29139 Tim
Edited by user Monday, July 11, 2016 4:00:27 PM(UTC)
Software says I'm on v9.0.9 Build 1184 However it says I'm on the latest build
>>Build 1184 That sounds like service pack 2. For a while we were doing time expired ViaCAD open betas including a 1193 build. Service pack 3, which is what we are working on now, will have this correction. Tim
How do I get this newer service pack?
Originally Posted by: HJ Nick How do I get this newer service pack?
When it is released, you will be to access the update from within the app Window: Current Version tool.
I'll also post in the forum when it is ready to download.
O ok, I just re-read what you typed and mis read it the first time. I'll keep an eye out. For now I'll sign up for the beta. Thanks again for the help.
