Gallery
Shelf support in piston-conrod design
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Hello to all - this is my first entry in this Forum.
My Name is Markus, I'm from Germany and I use ViaCad 2D/3D since Jan2015. I'm designing things for my Hobby - RC Cars and Trucks - and stuff for all day use and then print it on the 3D-printer. I like ViaCad verymuch and all the other Software I tried, was not so good in the usability. Also, I still use tinkercad for some stl-operations... perhaps this is obsolete with the powerpack?
Hers is one of my actual Projects: A shelf (Support) for my RC-Trucks (scale 1:14 / Tamiya based).
http://www.thingiverse.com/thing:1601646 Regards
Markus
Edited by user Wednesday, July 6, 2016 12:08:50 PM(UTC)
Kartoffel attached the following image(s):
(112kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Markus, many thanks for sharing!
What kind of tools are you using in tinkercad that are not in ViaCAD?
Edited by user Wednesday, July 6, 2016 7:07:06 PM(UTC)
Hello Tim,
the Import of stl-files (an changing them to volume) for further Operation is limited in Viacad 2d/3D (w/o powerpack) by the facettes. So I often upload these files in tinkercad making some easy boolean operations.
Another Thing I often use in tinkercad is the Import of svg-files, f.e. logos or cliparts, and then extrude them. > Ok, this should also be possible in Viacad...
But I would love to work only with in ViaCad!
At Amazon.de they offer a combinationpack of vcp + powerpack.
https://www.amazon.de/dp...em_r_mt_dp_RGFFxbX5RZWRF In the description it says:
Exklusiv mit dabei
• Koordinaten vergleichen
• Gitternetz an Objekt anpassen
Gitternetz zu Analytic konvertieren
Gitternetz zu NURB konvertieren
Is this the powerpack pro functionality to Import and Change all stl-files, beside the number of facettes?
Markus
Thanks: 230 times Was thanked: 182 time(s) in 110 post(s)
Originally Posted by: Kartoffel Hello Tim, Regards Markus
Hi Markus,
Do you prefer Kartoffel or patates frites for tonight ?
I'm working in Frankfurt half time, and in Paris the other half....
Jean-Louis
Salut Jean-Louis, then there are pumping two hearts in your chest tonight at the EM football game? I have loaded up my living room with several chips bags :-) Ciao Markus
Gallery
