murray
#1 Posted : Tuesday, July 5, 2016 6:12:48 PM(UTC)
murray
Kind of a technical one, maybe Tim will answer? I've been fooling with the open-source FreeCAD program, which has many useful Python macros, one of which unrolls ruled surfaces, but sometimes chokes. I'm wondering if I use surface extend on a ruled surface, does the extension extend along the ruling lines, so that the surface including extension is still a ruled surface that the FreeCAD macro might unroll?
#2 Posted : Tuesday, July 5, 2016 10:10:25 PM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Yes, the extended surface should still be a ruled surface.
As a quick check:
Edit: Change Object Type to Surface the Extended Surface
Select the surface and show the data entry tab of the inspector.
A ruled surface will have a degree v = 1. Degree 1 is linear. A degree 1 surface should be developable (unfold).
Do a Edit:Show Points to see the underlying control points
Edited by user Tuesday, July 5, 2016 11:13:41 PM(UTC)  | Reason: Not specified
murray
#3 Posted : Tuesday, July 5, 2016 11:06:05 PM(UTC)
murray
Thanks Tim! That's excellent.
Murray
