PowerPack
PowerPack Pro - Error SubD to Nurbs is not enabled for this product
Thanks: 9 times Was thanked: 4 time(s) in 1 post(s)
I am trying to convert a Mesh that was a STL import. I am running ViaCAD Pro v9 with PowerPack Pro.
I receive this error when trying to perform Mesh to Analytic (SubD to Nurbs is not enabled for this product) then I click OK and receive this error (Unable to convert mesh element into analytics).
I will attached the STL in question.
I will also attach a screenshot of my settings.
Please advise. Thanks.
Edited by user Thursday, June 2, 2016 7:29:26 AM(UTC)
STL and Screenshot.zip
(400kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Are you running ViaCAD Pro 64 out of the 64 bit folder? Some of the technology in PowerPack Pro requires using the 64 bit version of ViaCAD Pro. Tim
Originally Posted by: Tim Olson Are you running ViaCAD Pro 64 out of the 64 bit folder? Some of the technology in PowerPack Pro requires using the 64 bit version of ViaCAD Pro. Tim
I thought I was. I know I loaded it.
I just looked and cannot find ViaCAD in the 64-bit folder. Very strange.
I will dig further and try installing it again. I know I downloaded what you sent me and installed it.
BTW: for some reason I am not getting notifications via email for new posts on the forum.
I just tried to re-install ViaCADPro9_64_1198_NDRM.exe and the default install directory is: C:\Program Files (x86)\Punch! Software\ViaCAD Pro 9\ That is the 32-bit directory. My C:\Program Files path has no Punch or ViaCAD folders in it.
Hi James I made a Pro 64 build tonight based on the 1201 code stream and sent you a link. Let me know if this corrects the issue. TIm
PowerPack
