Instable ViaCAD v9 and impossible to re-install
Although my ViaCAD V9 worked the last two years quite well, suddenly the program became very unstable. After lot of searching for the reason I decided to re-install the program (on the same computer). However a "fingerprint" screen appears, asking for the acitivation-key. I thought I could use my old/original license key (done in may 2014). This does not work. Also re-intalling my V7 on this computer is impossible. So now I lost my ViaCAD, and have to buy a new one. You will understand that is not my intention. And resort to another program. A pitty, I was quite content with ViaCAD Javg
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
I think you just need to register it again.
>>So now I lost my ViaCAD, and have to buy a new one. Encore technical support should be able to help you out. You will need to contact them though as they do not monitor the forum. Tim
I tried already that, but up till now mailing to Encore is not very succesfull. I don'n expect much real help from them.
Hi javg What link did you send email too? Regards Jason
