Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
I added a font to the Windows Font folder, rebooted, and SharkFX PC 1201,
the font will not show up. How do you add a font to SharkFX?
Please take off the .vcp extension and try the font, thanks
Edited by user Wednesday, May 18, 2016 7:01:46 AM(UTC)
BanksScript.otf.vcp
(45kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Hi Larry, Have not tried the download yet, is it possible this is a bitmap font? Tim
Hi Larry Does the font show up in other programs like word or excel? Regards Jason
The Font does show up in Word 2016.
(59kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 48 times Was thanked: 85 time(s) in 57 post(s)
Hi, The Bank Script font is an OTF or Open Type Font. I can add this to the Mac using Font Book, but even after a restart I don't see it in Shark FX Font book is reporting an error "duplicate fonts found" when I try and install, but as I can see and use this in other apps (Notes & Text edit) maybe there is an issue here. Usually after a restart, and having quit Shark before it should load fonts, but I see the Mac in Font Book has All, Computer & User options, so it seems Shark (and ViaCad) are looking at the "Computer" font folder not All which includes user added. Mike
Thanks for trying Mike. Larry
There is a free font converter:
http://www.freefontconverter.com/ it will convert Open Type Fonts OTT to True Type Fonts TTF, and
a couple of other types.
SharkFX will now use the font, as a TTF, from the
Windows Font Folder, just in case anyone else has this problem.
