michaelclark
#1 Posted : Thursday, May 5, 2016 1:17:27 PM(UTC)
michaelclark
Nothing happens when I click on the inspector button. When I click on window and then inspector it will check mark. Then when I click on inspector nothing happens and then the check mark is gone in window
#2 Posted : Thursday, May 5, 2016 2:57:35 PM(UTC)
You might want to try resetting your dialog positions using the Prefs : General : Factory Page button.
michaelclark
#3 Posted : Thursday, May 5, 2016 3:02:24 PM(UTC)
michaelclark
nothing happened but a blinked screen still no inspector
rokoko
#4 Posted : Thursday, May 5, 2016 3:55:18 PM(UTC)
rokoko
maybe your inspector window is on a missing screen. on mac in such cases i will use "window wrangler" to bring the window into main screen. make sure that inspector window will be active (focus on inspector) when using window wrangler
michaelclark
#5 Posted : Saturday, May 14, 2016 8:57:20 AM(UTC)
michaelclark
I am using windows 10 I have a dual monitor display I just replaced on of the monitors and that's when this problem arose so certainly it sounds like what you have suggested. I have tried changing the resolutions on both monitors hoping that was the problem but I still cant find the inspector
Any suggestions?
michaelclark
#6 Posted : Monday, June 13, 2016 5:48:51 PM(UTC)
michaelclark
thank you I finally figured it out something monitor settings
