Welshter
#1 Posted : Friday, February 26, 2016 6:21:56 AM(UTC)
Welshter
I upgraded to the latest iteration of ViaCAD Pro V9 Build 1186.
I make screenshots from various angles of my drawings so that my customer can approve them before I make the detail drawings. With this version of the software no screen shots are being developed. In previous versions I get the option to choose the location that I save the files. I save them to dropbox for convenience for my customers. Nothing shows up in my dropbox folder. I opened preview and used the 'from clipboard' command in case the screenshot was saved there. But nothing there. There are no screenshot options in the preferences for ViaCAdPro V9.
I am using a MacBook Pro 2013 with OS 10.10.5 Yosemite.
Thank you, Welshter
#2 Posted : Friday, February 26, 2016 2:46:17 PM(UTC)
Hello Welshter
What command are you using to create screen shots? For example, I use
1. Edit : Copy BITMap (which copies the contents into mac paste buffer)
2. Launch Preview: New From ClipBoard
If you need dialog boxes and tool palettes, I use Command Shift 4.
Edited by user Friday, February 26, 2016 2:47:43 PM(UTC)  | Reason: Not specified
Craig
#3 Posted : Saturday, February 27, 2016 3:06:38 AM(UTC)
Craig
I use the render to file function for quick customer approval images.
Welshter
#4 Posted : Saturday, February 27, 2016 5:29:42 PM(UTC)
Welshter
I typically use Command Shift F4 so I can select the portion of the drawing I need to email to my customer. Now, I don't get see any response at all within VisCAD Pro V9. I tried the Edit Copy BITMap then open Preview New From Clipboard. I get a little blank white square in the middle of the page. I can export as a pdf file. Where is the 'render to file' function?
Thank you, Welsher
L. Banasky
#5 Posted : Saturday, February 27, 2016 7:41:39 PM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
Click on the Icon, Render To File.
Render to File.jpg (22kb) downloaded 5 time(s).
Render to File2.jpg (34kb) downloaded 5 time(s).
Welshter
#6 Posted : Monday, February 29, 2016 11:38:29 AM(UTC)
Welshter
Thank you, I'll try it.
