I upgraded to the latest iteration of ViaCAD Pro V9 Build 1186. I make screenshots from various angles of my drawings so that my customer can approve them before I make the detail drawings. With this version of the software no screen shots are being developed. In previous versions I get the option to choose the location that I save the files. I save them to dropbox for convenience for my customers. Nothing shows up in my dropbox folder. I opened preview and used the 'from clipboard' command in case the screenshot was saved there. But nothing there. There are no screenshot options in the preferences for ViaCAdPro V9. I am using a MacBook Pro 2013 with OS 10.10.5 Yosemite. Thank you, Welshter
Hello Welshter
What command are you using to create screen shots? For example, I use
1. Edit : Copy BITMap (which copies the contents into mac paste buffer)
2. Launch Preview: New From ClipBoard
If you need dialog boxes and tool palettes, I use Command Shift 4.
Edited by user Friday, February 26, 2016 2:47:43 PM(UTC)
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
I use the render to file function for quick customer approval images.
I typically use Command Shift F4 so I can select the portion of the drawing I need to email to my customer. Now, I don't get see any response at all within VisCAD Pro V9. I tried the Edit Copy BITMap then open Preview New From Clipboard. I get a little blank white square in the middle of the page. I can export as a pdf file. Where is the 'render to file' function? Thank you, Welsher
Thanks: 176 times Was thanked: 158 time(s) in 108 post(s)
Click on the Icon, Render To File.
(34kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
