Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
HI at all, if i export a ViaCad9 pro file as a wavefront .obj file a have two files one xyz.obj and one xyz.mtl but no files for textures and material. How can i export a Viacad file so i can use the materials / textures in Blender, Poser ? Thanks for help Matthias If there is any german speaking user for discuss problems with creating textures, please contact me.
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
Hi, Blender cannot use Shark materials, it can import basic colours if the part is exported with them, but the materials are in a Shark format (csm file).
Craig is correct, no textures exported to OBJ. Just RGB color per face.
The guys at posh.de probably know more than I do about the software! You might try them at:
http://support.posh.de Posh is also active in this forum, perhaps they will respond.
Edited by user Tuesday, November 24, 2015 1:31:32 AM(UTC)
Did you get a solution, I'm having the same problem exporting the texture, obj or png,
