Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
If I want to move layer 2 and it's sublayers to now be sub layers of layer one, how can I do this ? So right now layer 1 and two are both on level 1 and layer 2's sublayers are level 2. I want to change layer 2 to level 2 of layer 1 and it's sublayers would then be level 3. I hope this doesn't sound too confusing.
Thanks: 60 times Was thanked: 46 time(s) in 32 post(s)
Hi Solid td My method is to select everything I want to move in the layer, then go to the inspector, click on layer and there is your list of layers that you have created. Select the layer you want to move it to and apply.
If importing a bunch of layers from another design to use it is rather time consuming to have to recreate all the layers and move all the objects over. Is there any chance that in a future update we will be able to change a layer to a sublayer of another ?
>> Is there any chance that in a future update we will be able to change a layer to a sublayer of another Yes it is on the list of items to consider for v10. Tim
