Art Smith
#1 Posted : Monday, February 15, 2016 12:49:31 PM(UTC)
Art Smith
Was thanked: 26 time(s) in 15 post(s)
does Shark FX9 support trimming surfaces with a solid? if so, where to I find the tool and/or an example of the command sequence??
Art
[email protected]
#2 Posted : Monday, February 15, 2016 1:28:49 PM(UTC)
Was thanked: 234 time(s) in 203 post(s)
Hello Art
The Surface Subtract tool might be an option for you.
Edited by user Monday, February 15, 2016 1:41:47 PM(UTC)  | Reason: Not specified
Screen Shot 2016-02-15 at 1.28.04 PM.png (172kb) downloaded 5 time(s).
Vice President Software Development
Art Smith
#3 Posted : Monday, February 15, 2016 1:56:40 PM(UTC)
Art Smith
Tim-
thanks!! the surface subtract tool provides most of what I'm looking for. how do I eliminate the closed end added by the tool; ie: subtracting a solid cylinder from a tubular surface "closes" the subtracted end of the tubular surface??
Art
[email protected]
subtracting solid from tubular surface.jpg (37kb) downloaded 6 time(s).
#4 Posted : Monday, February 15, 2016 2:01:40 PM(UTC)
Select the unwanted face using the Deep Select tool and click the Delete key. I've updated this in 1186 to avoid the extra delete step.
Edited by user Monday, February 15, 2016 4:09:20 PM(UTC)  | Reason: Not specified
Screen Shot 2016-02-15 at 2.34.55 PM.png (133kb) downloaded 5 time(s).
Art Smith
#5 Posted : Monday, February 15, 2016 4:09:11 PM(UTC)
Art Smith
Tim-
thanks, the unwanted surface is gone. however, use of the same surface subtract tool now yields an ACIS Error...............
Art
[email protected]
surface subract number two.jpg (49kb) downloaded 7 time(s).
solidtooldesigns
#6 Posted : Monday, February 15, 2016 7:55:17 PM(UTC)
solidtooldesigns
I get this error trying to do the same thing sometimes. If its a straight cut like that looks like it is you can split the surface using an infinite plane. You can also use surface intersect in this case and use the resulting curve to split the surface, delete the unwanted side. if the curve doesn't completely split the surface first try, extend the curve lines.
Since this looks like a straight split though I would split it using the infinite plane.
Another option is to thicken the surface and try the boolean subtract now that they are both solids. Once you have the solid you want, offset the surface you want with a value of "0", keep the surface and delete the solid.
Edited by user Monday, February 15, 2016 7:57:10 PM(UTC)  | Reason: Not specified
Art Smith
#7 Posted : Monday, February 15, 2016 9:33:05 PM(UTC)
Art Smith
Solidtooldesgigns-
THANKS, that works for all remaining trimming!!
any ideas on drawing/constructing ellipses on the tubular surface OR a curved surface in only one direction??
Art
[email protected]
elilipses on the surface.jpg (46kb) downloaded 5 time(s).
solidtooldesigns
#8 Posted : Monday, February 15, 2016 9:57:46 PM(UTC)
solidtooldesigns
make work planes as perpendicular as possible to the areas of the tubular surface you are working on and draw ellipses, then use the project curve surface tool to project those ellipses to the tubular surface. Another faster way could be to extrude an elipse and rotate it as perpendicular as possible to the different areas of the tubular surface and use the intersect tool to generate curves and split and delete the leftover or just try to split with the extrusion itself (fastest). I'm sure there are better ways then these. I'm pretty primitive.
Art Smith
#9 Posted : Tuesday, February 16, 2016 1:02:43 AM(UTC)
Art Smith
Solidtooldesgigns-
thanks again for the ideas. unfortunately it's a fluid mechanics application that will not allow the chord approximation for the arc length (ie: extrusion options). I've found the curve projection onto a plane tool; is there an equivalent tool for onto a surface??
Art
[email protected]
solidtooldesigns
#10 Posted : Tuesday, February 16, 2016 6:46:26 AM(UTC)
solidtooldesigns
Project Curve Surface. Second from the left on that toolbar.
Antoine
#11 Posted : Tuesday, February 16, 2016 7:17:10 AM(UTC)
Antoine
Switzerland
Was thanked: 31 time(s) in 25 post(s)
hello,
for your help.
http://www.screencast.com/t/8suewY8CwKSa
Antoine
Art Smith
#12 Posted : Tuesday, February 16, 2016 11:22:41 AM(UTC)
Art Smith
Antoine-
huge thanks; I've finally literally and figuratively got the "dots connected"! leading edge and trailing edge geometry complicates the situation but it's the same functionality.
thanks again!
Art
[email protected]
ellipses on surface two.jpg (48kb) downloaded 7 time(s).
Antoine
#13 Posted : Wednesday, February 17, 2016 2:41:53 AM(UTC)
Antoine
Switzerland
