L. Banasky
#1 Posted : Sunday, February 14, 2016 10:12:54 AM(UTC)
L. Banasky
When trying the Architecture Draw Tools, I was curious about why an UNDO of the
SLAB, indicated an UNDO of a Roof.
Not really the best solution, but If a roof is really needed:
Draw the connected walls, select one wall, and enter a height, a choice will be
offered to ‘Change all connected walls’, check ‘yes’.
Draw the ‘SLAB’ from the Architecture Tool Bar, CTRL move and copy to the
wall tops.
Change the ‘Height and Draft’ to negative values, I just entered -60, try different
values.
‘SHELL’, and then ‘SCALE’ 1.125 for an overhang. ‘MOVE’ if needed.
Untitled 1.vcp (30kb) downloaded 7 time(s).
Architecture slab tool.jpg (78kb) downloaded 10 time(s).
Change all connected walls.jpg (58kb) downloaded 9 time(s).
Scale for overhang.jpg (77kb) downloaded 8 time(s).
