francois charron
#1 Posted : Wednesday, November 20, 2013 5:50:51 AM(UTC)
francois charron
Was thanked: 17 time(s) in 6 post(s)
Hi all,
It's a long time I have used Shark (and concept unlimited) to do my designs.
I posted some pictures of products I designed. All of this products are marketed now.
Bye,
francois charron attached the following image(s):
ABRI SERVICES ALM.jpg (83kb) downloaded 16 time(s).
MD VITALIT V6000.jpg (107kb) downloaded 21 time(s).
NAONEXT Crystall-Ball.jpg (62kb) downloaded 18 time(s).
JEGOU valise ES 2.jpg (132kb) downloaded 19 time(s).
AQUAROLL Roll N'Care.jpg (78kb) downloaded 17 time(s).
CASTEL ceinture VDIP.jpg (70kb) downloaded 18 time(s).
DROMAD Via Kaba.jpg (135kb) downloaded 16 time(s).
ERCO & GENER coffret IP67.jpg (86kb) downloaded 19 time(s).
EVOLIS Primacy.jpg (58kb) downloaded 17 time(s).
ISOSIGN gamme.jpg (90kb) downloaded 18 time(s).
la mouche
#2 Posted : Wednesday, November 20, 2013 7:17:18 AM(UTC)
la mouche
Salut,
Beau travail!
Bravo.
Je participe ©galement sur le forum de Luxion sous le pseudo: Antoine
Antoine
Jean-Francois Jacques
#3 Posted : Thursday, November 21, 2013 11:52:23 AM(UTC)
Canada
.....good job!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#4 Posted : Friday, November 22, 2013 11:06:11 AM(UTC)
Trs beau travail Franois !
----French Connection----
misterrogers
#5 Posted : Friday, November 22, 2013 2:25:03 PM(UTC)
misterrogers
REALLY nice work!
misterrogers
#6 Posted : Wednesday, November 27, 2013 12:27:44 PM(UTC)
misterrogers
Originally Posted by: francois charron Go to Quoted Post
Hi all,
Bye,
Just a question about your renderings, did you create all your text inside of Shark? Are they just decals? Or added in photoshop later?
Thanks.
francois charron
#7 Posted : Friday, November 29, 2013 4:17:39 PM(UTC)
francois charron
I prefer to model texts in Shark when they are simples (drawn in Illustrator and imported to Shark - I can reuse the .ai file to make printed-screen after in production).
In the case of complex pictures (Like Abri Services or Jegou), I use a decal.
I never use Photoshop to correct or change an image after rendering (it's not my professional philosophy).
I would precise that these products are entirely designed in Shark - from concepts to the industrial production documents. For the Evolis and Aquaroll products the inner parts are designed in Pro_E and Solidworks. I never had a problem to exchange data between them.
I use Keyshot to have a very good quality and Artlantis for the productivity.
You can see some others products in my web site : www.exadesign.com. I will add some others products pictures before Christmas if I have the time to take photos.
Francois
PS : sorry for my english. I post some new products for the pleasure.
SYNEIKA neuronavigateur.jpg (37kb) downloaded 11 time(s).
LAUDREN Laerdal - coffret d©fibrillateur.jpg (55kb) downloaded 13 time(s).
FDI t©l©commande et cl© 2013.jpg (55kb) downloaded 11 time(s).
STRYKER SK28.jpg (37kb) downloaded 11 time(s).
la mouche
#8 Posted : Tuesday, December 3, 2013 5:08:21 AM(UTC)
la mouche
bravo,
je suis trs impressionn© par ta production, forte qualitative et ©motionnelle.
Antoine
la mouche
#9 Posted : Tuesday, December 3, 2013 5:15:52 AM(UTC)
la mouche
Bonjour Franois,
j'ai une question:
utilise tu Shark pour tes mise en plans technique 2d?
Je me bats depuis de nombreuses ann©es avec Shark, CU, ... afin d'obtenir des plans techniques de qualit©, mais rencontre toujours les mmes bug et incoh©rences dans ce type de travail.
C'est quelquefois, rendre fou.... je n'exagre pas.
Autant j'adore ce logiciel pour mes travaux de mod©lisation, autant je le d©teste pour le mode MTS, mise en plans.
Je parle surtout des raffinements, lignes, polices, hachures etc, tellement difficiles mettre en oeuvre et sans compter les bug, disparition, incoh©rences etc.
Je me suis mme demand© si je ne devrais pas changer de logiciel, juste pour cette partie de dessin 2d...
Je suis trs curieux de ta r©ponse.
Sinon, j'ai peu prs les mmes routines que toi, soit: mod©lisation avec SharkFX et rendus avec Keyshot que j'adore.
Cordialement.
Antoine
#10 Posted : Tuesday, December 3, 2013 9:59:19 AM(UTC)
To translate Antoine's comment in a few words :
"Tim, please, fix the bugs in MTS".
la mouche
#11 Posted : Tuesday, December 3, 2013 10:08:49 AM(UTC)
la mouche
hahahhahahahahahaha!!!
Thanks JLM
maybe for the 12 version....
francois charron
#12 Posted : Friday, December 6, 2013 10:26:42 AM(UTC)
francois charron
Salut,
Je fais ma mise en plan sous shark pour les cotes simplement.
Tout le reste est fait dans Illustrator : police, couleurs, sp©cifications, cartouche, ajout d'images
Car effectivement shark bloque rapidement en souplesse.
Je joins le type de plans que je peux faire.
salut et bon week-end,
Franois
chassis tolerie.pdf (1,737kb) downloaded 11 time(s).
fonderie alu.pdf (278kb) downloaded 12 time(s).
la mouche
#13 Posted : Friday, December 6, 2013 3:11:23 PM(UTC)
la mouche
Merci beaucoup Franois,
Tim? entends tu? lis tu?
Ecoute les pros...les vrais, ceux qui ont besoin de raffinements, enfin le minimum requis pour cr©er des plans dignes de ce nom :)
Cordialement.
Antoine
#14 Posted : Friday, December 6, 2013 3:59:16 PM(UTC)
Canada
Antoine, if you write your comment in french, for sure Tim didn't read it!
Guest (13)
