jbskaggs
#1 Posted : Monday, February 8, 2016 11:14:41 AM(UTC)
jbskaggs
When I get my models done I do not get the effects I want in rendering for promotional / sales use. Are there people who willing to just render a viacad model affordably?
L. Banasky
#2 Posted : Monday, February 8, 2016 11:54:03 AM(UTC)
L. Banasky
I believe there are add-ons for ViaCad for rendering.
Sketchup also has add-ons for rendering.
http://www.suplugins.com...-whatsnew-August2015.php
You could export as Dwg or Dfx, or 3D Max and then import into Sketchup.
I'm not sure what your options are in ViaCad.
Give Tim's book a try.
http://masterviacad.com/...acadtips/viacadtips.html
As far as learning the software, just keep using it, best way
to learn.
There are always different ways to achieve the same model.
Learn from your mistakes.
Plus, where else can you post a problem on Superbowl Weekend and
have someone who will respond.
This Forum, with Tim's guidance and help is great.
Edited by user Monday, February 8, 2016 11:54:53 AM(UTC)  | Reason: Not specified
mariko twin over twin .skp.vcp (872kb) downloaded 5 time(s).
mariko twin over twin.3ds.zip (253kb) downloaded 5 time(s).
Craig
#3 Posted : Tuesday, February 9, 2016 2:00:58 AM(UTC)
Craig
Do you have an example of what you would like rendered, if so attach it in OBJ format and I will take a look for you?
