jbskaggs
#1 Posted : Sunday, February 7, 2016 2:26:22 AM(UTC)
jbskaggs
If I save a model with several objects as a symbol. Then I load those into a new model via Concept Explorer/ symbols it loads fine.
but I cannot move scale or rotate the symbol. it gives me a Cannot render this feature error. They way I get the error to stop is to un group the objects- then one at a time select them with shift-click only then can I use them normally. Otherwise selection by box or ctrl a gives the same error cannot render feature.
attached is the model I saved to symbols.
Edited by user Sunday, February 7, 2016 2:27:52 AM(UTC)  | Reason: Not specified
mariko long rail.vcp (684kb) downloaded 7 time(s).
L. Banasky
#2 Posted : Sunday, February 7, 2016 4:08:28 AM(UTC)
L. Banasky
I think the problem is with 2 small circles.
Do a 'Hide all objects', then 'Show all curves', Select all'
and Delete the curves.
Do a 'Show all objects' and you should be good to go.
mariko long rail-1.vcp (677kb) downloaded 7 time(s).
jbskaggs on 2/7/2016(UTC)
jbskaggs
#3 Posted : Sunday, February 7, 2016 9:11:59 AM(UTC)
jbskaggs
So when you use a line or circle to make a hole etc-- it does not automatically delete those lines when the push / pull is done?
BTW thanks for the help!
jbskaggs
#4 Posted : Sunday, February 7, 2016 9:18:13 AM(UTC)
jbskaggs
I just tested your suggestion and worked like a charm!
rokoko
#5 Posted : Sunday, February 7, 2016 3:05:44 PM(UTC)
rokoko
no, the lines/curves stay in the drawing, they are "sketches". later you can change parameters on that sketch and your extrusion/push-pull etc will follow (associativity). in the picture i drew a circle on top of a block and did a push-pull. when selecting the circle i'm able to change diameter of the protrusion. i also can move the sketch - try it!
if you don't want to see the sketches in your drawing, then hide them or move them to a hidden layer.
jbskaggs
#6 Posted : Sunday, February 7, 2016 3:09:36 PM(UTC)
jbskaggs
but then don't these circles then cause the error listed above? Im sorry but this is confusing to me.
rokoko
#7 Posted : Sunday, February 7, 2016 3:23:47 PM(UTC)
rokoko
ok, for a symbol the sketches can cause trouble. you can delete the sketches in a finished model before doing a save as symbol.
Guest (5)
