solidtooldesigns
#1 Posted : Thursday, February 4, 2016 6:56:56 AM(UTC)
solidtooldesigns
I really like that if I have a pocket or profile I can just pull the pocket up until there is no more depth and it is basically deleted / gone. When you do the reverse and pull down I would like it to become "thru" if you pull it beyond the boundary of the object it is in. Right now it is kind of buggy. See attached video. Are there any plans to make that last example a thru hole ?
2016-02-04_07-53-34.mp4 (2,181kb) downloaded 25 time(s).
#2 Posted : Thursday, February 4, 2016 3:20:58 PM(UTC)
I need to fix that and make it a hole. I recently saw some SketchUp demos where this made a hole through.
Craig
#3 Posted : Thursday, February 4, 2016 4:38:27 PM(UTC)
Craig
Works on V9 just fine.
thefro
#4 Posted : Thursday, February 4, 2016 4:43:49 PM(UTC)
thefro
i am finding with the coach solid i hollowed out i was able the use the gripper to push all of the way through where i could not with previous builds. but it only works the first time. if you work on the hole again i get the same result as the video Build 1165b
i have another two issues i will post after the weekend. i have seen for some builds.
Best Regards
Brian
