Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
When using cover surface tools you get asked to select the curves but if there is another surface touching one of the curves Shark will add that surface to the list, the curves should only be selectable in such a situation and surfaces/solids should be ignored.
In addition to stand alone curves, you can select the edge of a surface or solid as input to the cover surface. Tim
I realise that Tim but the procedure I need is curves only, it kills workflow having to select between edges and surfaces every time, the program is saying select the curves and not surface edges.
