View rotation problem in build 1184 trial
I'm trying out ViaCAD V9 for the first time via the free 15 day trial and I'm having some difficulty with rotating the view. When I do so, it will randomly 'stick' and stop turning, even as my mouse continues to move across the screen. This doesn't appear to happen for vertical rotation, nor for panning or zooming. I assume this is not intended. I'm running build 1184 on Windows 7 64bit. Any advise? Thanks.
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Try selecting an object and then rotating. I find rotating with nothing selected can be sticky too.
Originally Posted by: solidtooldesigns Try selecting an object and then rotating. I find rotating with nothing selected can be sticky too.
Hmm.. that doesn't seem to have an effect. So you experience the same issue?
Are you seeing this issue with all files or a particular model? Selecting an object forces the rotation point about the selected object. Do you also see the problem when using the view rotate tool from the view menu? Tim
Originally Posted by: Tim Olson Are you seeing this issue with all files or a particular model? Selecting an object forces the rotation point about the selected object. Do you also see the problem when using the view rotate tool from the view menu? Tim
I have the issue with any or no model loaded and using both the rotate tool and the MMB.
