jsmith
#1 Posted : Sunday, January 31, 2016 9:54:47 PM(UTC)
jsmith
I'm trying out ViaCAD V9 for the first time via the free 15 day trial and I'm having some difficulty with rotating the view. When I do so, it will randomly 'stick' and stop turning, even as my mouse continues to move across the screen. This doesn't appear to happen for vertical rotation, nor for panning or zooming. I assume this is not intended. I'm running build 1184 on Windows 7 64bit. Any advise? Thanks.
solidtooldesigns
#2 Posted : Sunday, January 31, 2016 10:42:51 PM(UTC)
solidtooldesigns
Try selecting an object and then rotating. I find rotating with nothing selected can be sticky too.
jsmith
#3 Posted : Monday, February 1, 2016 12:02:00 AM(UTC)
jsmith
Hmm.. that doesn't seem to have an effect. So you experience the same issue?
#4 Posted : Monday, February 1, 2016 10:45:48 AM(UTC)
Are you seeing this issue with all files or a particular model? Selecting an object forces the rotation point about the selected object.
Do you also see the problem when using the view rotate tool from the view menu?
jsmith
#5 Posted : Monday, February 1, 2016 10:49:19 AM(UTC)
jsmith
I have the issue with any or no model loaded and using both the rotate tool and the MMB.
