New to ViaCAD, How do Assemblies work?
Hey, I new to ViaCAD, I currently use Alibre Design but I not excited about upgrading to the new version. So I am looking for an alternative. I design 1/6 scale hobby models as a part time hobby and sometimes I sell the designs. So I need to design complex assemblies of many different small parts. I realize ViaCAD dose not seem to support separate parts and assemblies like my current tool. From reading topics at this forum it seems like people design individual part files and then import them into large assembly files. I also seem that people seem to use "layers" to hide detail in the assembly and even make each part its own layer. It seems like the "import" approach is restrictive because once you import the part, you can't change the original without deleting it from the assembly and re-importing it. In some of the examples I have also seem "things" labeled as parts vs. the basic lines and such. So I am wondering if someone could describe the general workflow? Can you create multiple parts in the same file, or do you need to create separate files and import them to create parts? What is the approach to produce complex assemblies? Is ViaCAd the right tool for these types of projects? I have gone through the Users manual but if there is something else to read that would be great. Thanks, Dale
Hi Dale
Since ViaCAD and GD use ACIS, SAT is a good choice to share data.
ViaCAD supports a flat file architecture where all the data typically resides in one file. Layers and sublayers are often used to manage and organize data related to parts within the file. For example you could:
Top Layer : Part 45
Sub Layer 1: Dimensions/annotation
Sub Layer 2: Profiles/Sketches/Constructions
Sub Layer 3: .....
Just curious, changes in licensing or features?
FYI, I've got a variety of videos regarding ViaCAD at the masterviacad site below that may help you get up to speed.
http://masterviacad.com/videos/page7.html Tim
Edited by user Friday, January 29, 2016 12:21:06 AM(UTC)
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
I have found that with complex assemblies it is always better to model individual parts and then import them into a final assembly, this does not only apply to Viacad or Shark, it also applies to programs like Solidworks and Autocad.
Edited by user Friday, January 29, 2016 2:31:10 AM(UTC)
One big difference you may have to get use to is that ViaCAD does not have constraints. So there is no way to drive geometry using constraints.
