grumpygeek
#1 Posted : Tuesday, January 26, 2016 2:50:44 PM(UTC)
grumpygeek
Hi all,
I am wondering if there is a recommended way to manage working with models and generated sheet views? I have machine I have modeled that has about 50 sheet views and if I have to modify a part the "regening" can take about 15 minutes. I tried disabling it in the general profile settings, but it (regen) still kicks off if I use undo, try to type in a value for a move distance, or other random offenses I have yet to determine. Is there a way to disassociate a sheet view from the model, I would rather regenerate a sheet view and redo the dimensions than struggle thru changing things.
Don B.
Viacad 9 Pro SP1
#2 Posted : Tuesday, January 26, 2016 3:14:23 PM(UTC)
Hi Don
Use the Flatten View option.
You can also use the "Regen Manually" option for the view. Then use the Regen View to update when you want(last tool icon in palette).
grumpygeek
#3 Posted : Tuesday, January 26, 2016 10:51:50 PM(UTC)
grumpygeek
I'll give those a try, Thanks.
