Helix with Draft Angle 1-rail Sweep
vcad9Pro win32
i created a helix with draft angle, and then a circle at an endpoint of helix, but when i do 1-rail sweep the solid sweep didnt follow the helix path. vcp attached.
Edited by user Monday, January 25, 2016 9:52:40 AM(UTC)
helix-draft-angle.vcp
(3,686kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
Try putting the circle at the bottom of the path instead of the top. Will look into further regarding placement at the top.
Edited by user Monday, January 25, 2016 1:57:03 PM(UTC)
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
Seems to work on a right view with 'Sweep Perp.' from the top.
helix-draft-angle2.sfx
(3,720kb) downloaded 6 time(s). L. Banasky attached the following image(s):
(185kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: L. Banasky Seems to work on a right view with 'Sweep Perp.' from the top. Larry
does it make a difference that you used SharkFX vs VC9Pro that i used?
Thanks: 8 times Was thanked: 77 time(s) in 39 post(s)
CNC_Kid,
I had the same result as you, but when I moved the circle to the other end of the helix it worked. I wonder if sweeping in the same direction as the helix is needed. I couldn't change the direction of the helix.
(677kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
Hi Larry, what tool pallet is displayed on your desktop?
Hi Craig,
It's Show-Hide, easier for me to show and hide objects.
(69kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: CNC_Kid Originally Posted by: L. Banasky Seems to work on a right view with 'Sweep Perp.' from the top. Larry
I don't have VC9Pro, but I think they are developed from the same platform.
Originally Posted by: mitchb CNC_Kid, I had the same result as you, but when I moved the circle to the other end of the helix it worked. I wonder if sweeping in the same direction as the helix is needed. I couldn't change the direction of the helix.
its interesting, only because if you sweep from the top it actually does a sweep, but not the expected sweep. this odd behavior seems to only be there when there is draft angle, if its a std helix i can sweep it from top or bottom, etc. it would be an annoyance to have to sweep every rail from its start point if you have many rails created in varying directions as a 1st step in building some CAD work.
Edited by user Tuesday, January 26, 2016 6:18:17 AM(UTC)
