CNC_Kid
#1 Posted : Monday, January 25, 2016 9:50:08 AM(UTC)
CNC_Kid
vcad9Pro win32
i created a helix with draft angle, and then a circle at an endpoint of helix, but when i do 1-rail sweep the solid sweep didnt follow the helix path. vcp attached.
Edited by user Monday, January 25, 2016 9:52:40 AM(UTC)  | Reason: Not specified
helix-draft-angle.vcp (3,686kb) downloaded 13 time(s).
VCpro v11-1417
Win10Pro 32GB
Xeon E3-1270-v3 3.5GHz
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
#2 Posted : Monday, January 25, 2016 11:45:12 AM(UTC)
Try putting the circle at the bottom of the path instead of the top. Will look into further regarding placement at the top.
Edited by user Monday, January 25, 2016 1:57:03 PM(UTC)  | Reason: Not specified
L. Banasky
#3 Posted : Monday, January 25, 2016 12:59:53 PM(UTC)
L. Banasky
Seems to work on a right view with 'Sweep Perp.' from the top.
helix-draft-angle2.sfx (3,720kb) downloaded 6 time(s).
CNC_Kid
#4 Posted : Monday, January 25, 2016 9:33:16 PM(UTC)
CNC_Kid
does it make a difference that you used SharkFX vs VC9Pro that i used?
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
mitchb
#5 Posted : Tuesday, January 26, 2016 1:09:55 AM(UTC)
mitchb
CNC_Kid,
I had the same result as you, but when I moved the circle to the other end of the helix it worked. I wonder if sweeping in the same direction as the helix is needed. I couldn't change the direction of the helix.
Screen Shot 1.png (677kb) downloaded 8 time(s).
Craig
#6 Posted : Tuesday, January 26, 2016 1:28:07 AM(UTC)
Craig
Hi Larry, what tool pallet is displayed on your desktop?
L. Banasky
#7 Posted : Tuesday, January 26, 2016 3:07:48 AM(UTC)
L. Banasky
Hi Craig,
It's Show-Hide, easier for me to show and hide objects.
L. Banasky
#8 Posted : Tuesday, January 26, 2016 4:44:14 AM(UTC)
L. Banasky
I don't have VC9Pro, but I think they are developed from the same platform.
CNC_Kid
#9 Posted : Tuesday, January 26, 2016 5:59:02 AM(UTC)
CNC_Kid
Originally Posted by: mitchb Go to Quoted Post
CNC_Kid,
its interesting, only because if you sweep from the top it actually does a sweep, but not the expected sweep. this odd behavior seems to only be there when there is draft angle, if its a std helix i can sweep it from top or bottom, etc. it would be an annoyance to have to sweep every rail from its start point if you have many rails created in varying directions as a 1st step in building some CAD work.
Edited by user Tuesday, January 26, 2016 6:18:17 AM(UTC)  | Reason: Not specified
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
