gaya
#1 Posted : Saturday, January 2, 2016 9:00:23 PM(UTC)
gaya
Hello,
I have the following problem. When I hatch or fill an object, I can not move it afterwards. It kind of gets stuck on one spot. After a few tries, it might move one or 2 times, then again gets stuck. CAn anyone help with this? What am I doing wrong?
Thanks!
#2 Posted : Monday, January 4, 2016 10:06:44 AM(UTC)
Try moving the objects that define the hatch. The hatch position is defined by these objects.
Use Edit :Remove Links to delete the dependency.
gaya
#3 Posted : Friday, January 15, 2016 9:23:10 PM(UTC)
gaya
Thanks, I will try that.
