Andrew Gray
#1 Posted : Wednesday, January 13, 2016 4:14:50 AM(UTC)
Andrew Gray
Hi all
Using VC9 can I draw a shape and add dims to constrain the sketch (like solid works)
Antoine
#2 Posted : Wednesday, January 13, 2016 8:34:29 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
hello,
This option existed in version 8.
Tim?
Why you it has disappeared from v.9?
Antoine
Antoine attached the following image(s):
posh.de
#3 Posted : Wednesday, January 13, 2016 11:25:56 AM(UTC)
posh.de
Shark/ViaCAD are direct modelers, the (limited) constraints (third party software) were removed for all recent Punch!CAD products with a small user demand in contradiction to the royalties to pay for every copy.
Norbert
Craig
#4 Posted : Thursday, January 14, 2016 1:50:33 AM(UTC)
Craig
Norbert
Does this mean that we are never going to get rid of the model to sheet information box, the model to sheet issues and get the roof tool back on V9?
posh.de
#5 Posted : Thursday, January 14, 2016 4:45:33 AM(UTC)
posh.de
MTS and architectural tools do obvioulsy have nothing to do with constraints.
Andrew Gray
#6 Posted : Thursday, January 14, 2016 2:04:12 PM(UTC)
Andrew Gray
Hi all
I understand that vc9 is direct modeller like sketchup, or designspark mechanical
I like the model to sheet to make 2d plans can't go wrong with $75
Andrew Gray
#7 Posted : Thursday, January 14, 2016 2:04:47 PM(UTC)
Andrew Gray
Hi all
#8 Posted : Thursday, January 14, 2016 2:48:51 PM(UTC)
ViaCAD supports the following modeling methods
--Associative curve, surface, and solids. (modify a curve, the surface/solid and dependents update)
--Direct face modeling (move, offset, match, remove, rotate face independent of features)
--History Tree with Editable features (holes, cutouts, shells, fillet, blend)
--Basic subdivision/mesh tools (more coming in v10)
Guest (8)
