Jean-Francois Jacques
#1 Posted : Monday, January 11, 2016 12:36:24 PM(UTC)
Canada
Tim how can we select mesh like my example ? (inside of object) ...you know we don't have ambiguity window.
Jean-Francois Jacques attached the following image(s):
Screen Shot 2016-01-11 at 13.29.58.png (48kb) downloaded 5 time(s).
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#2 Posted : Monday, January 11, 2016 7:41:44 PM(UTC)
Box select each of the four face vertixes.
We plan to update the selection of vertices, edges and faces.
#3 Posted : Tuesday, January 12, 2016 9:02:20 AM(UTC)
Canada
Box select ..what do you mean,(Tool Box selection)? I used Select Edge for each vertex.
Craig
#4 Posted : Wednesday, January 13, 2016 1:30:15 AM(UTC)
Craig
Drag the selection tool over each of the four vertices, do it individually then you stand less chance of picking up any vertices behind the ones you want to select. Box select is draging the pointer over an area that you want to select, but you often pick up vertices behind the ones you want so I box select vertices individually or in groups if there is nothing behind them.
