flatpack
#1 Posted : Sunday, January 03, 2016 3:29:00 AM(UTC)
flatpack
Was thanked: 10 time(s) in 8 post(s)
Any subdivision volume I create seems to be invisible. I can "see" its points only when I select it. Here's a snapshot to show. My pen and fill colors are set to Black. I tried restarting to no avail. Please advise what could be wrong.
Screen Shot 2016-01-03 at 4.23.58 PM.png (536kb) downloaded 27 time(s).
flatpack
#2 Posted : Sunday, January 03, 2016 3:50:02 AM(UTC)
flatpack
ALso I just realized that when I create a solid volume, like a block primitive for example and Change Object Type to a Mesh, the outcome is also an invisible object. Only can be seen when I drag-select over it and the points show up. Just the points - no object.
By the way I am using Shark LT v9.
GARLIC
#3 Posted : Sunday, January 03, 2016 4:48:24 AM(UTC)
GARLIC
Was thanked: 14 time(s) in 12 post(s)
What are your settings under View/Shade Options for:
Static Shade ?
Dynamic Shade ?
Shade Now ?
Please check these setting...
best wishes !
thanks 1 user thanked GARLIC for this useful post.
flatpack on 1/3/2016(UTC)
flatpack
#4 Posted : Sunday, January 03, 2016 8:12:25 AM(UTC)
flatpack
Static Shade ?
Dynamic Shade ?
Shade Now ?
best wishes !
Absolutely! That fixed it. Everything was set to "hidden with dimmed" which seems to show the other solid objects fine, but no SubD volumes. Thanks a million Garlic.
#5 Posted : Monday, January 04, 2016 10:04:19 AM(UTC)
Was thanked: 202 time(s) in 178 post(s)
You might want to check your color assigned to mesh edges. They might be white.
Prefs: Display : Surface : Edge Color
TIm
Edited by user Monday, January 04, 2016 10:05:04 AM(UTC)  | Reason: Not specified
ViaCAD/Shark Development Team
Links to ViaCAD Resources
