Issue with most recent build 1166
Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I'm running build 1166 on a PC. Currently the snaps will not work on grouped objects and when changing text to line, it no longer deleted the original text (I do have it selected to delete the original). Before updating neither of these were an issue. This causes quite an issue for the work I am doing, sure hope there is a quick fix.
Views messages in topic : 5,454
>>Currently the snaps will not work on grouped objects and when changing text to line, I believe this is corrected in the beta builds. We trying to get a few more corrections in before it is released as a general service pack. Tim
Originally Posted by: Dyn_Metalworks I'm running build 1166 on a PC. Currently the snaps will not work on grouped objects and when changing text to line, it no longer deleted the original text (I do have it selected to delete the original). Before updating neither of these were an issue. This causes quite an issue for the work I am doing, sure hope there is a quick fix.
Is anyone else tired of this bug yet......I think it is time to fix it for us. It is more than just a nuisance. Come on folks, its been long enough
Is this 2D3D or Pro? I'll see if I can get a build to tech support until Encore does a general update. Tim
Originally Posted by: Tim Olson Is this 2D3D or Pro? I'll see if I can get a build to tech support until Encore does a general update. Tim
Both programs have the same issue....I run Pro on PC and 2D3D on Mac.
I'm using 2d/3d
Group moves still do not work. When is the patch due out?
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
Problems with groups go way back, I have never been able to use the function because when I move a group of objects and then undo, many times components will appear from nowhere and they end up all over the place.
>>When is the patch due out? Encore QA is getting ready to release ViaCAD SP2 next week. It will available from within the help : current version. Tim
Originally Posted by: Tim Olson >>When is the patch due out? Encore QA is getting ready to release ViaCAD SP2 next week. It will available from within the help : current version. Tim
is there a new release according to the snap/group topic for a german version too?
Martin
>>is there a new release according to the snap/group topic for a german version too? Hi Martin The 1181 build is available from the Help : Current Version tool for German. I believe the snap/group issue should be corrected in that build. Tim
