defkon
#1 Posted : Sunday, November 22, 2015 6:22:04 AM(UTC)
defkon
HI at all,
if i export a ViaCad9 pro file as a wavefront .obj file a have two files one xyz.obj and one xyz.mtl but no files for textures and material.
How can i export a Viacad file so i can use the materials / textures in Blender, Poser ?
Thanks for help
Matthias
If there is any german speaking user for discuss problems with creating textures,
please contact me.
Craig
#2 Posted : Monday, November 23, 2015 9:29:29 AM(UTC)
Craig
Hi, Blender cannot use Shark materials, it can import basic colours if the part is exported with them, but the materials are in a Shark format (csm file).
#3 Posted : Tuesday, November 24, 2015 1:29:55 AM(UTC)
Craig is correct, no textures exported to OBJ. Just RGB color per face.
The guys at posh.de probably know more than I do about the software! You might try them at: http://support.posh.de
Posh is also active in this forum, perhaps they will respond.
Edited by user Tuesday, November 24, 2015 1:31:32 AM(UTC)  | Reason: Not specified
Jose
#4 Posted : Monday, February 22, 2016 9:01:38 AM(UTC)
Jose
Did you get a solution, I'm having the same problem exporting the texture, obj or png,
