Thanks: 7 times Was thanked: 2 time(s) in 2 post(s)
I am currently using Shark LT V8, do any of the newer products convert pdf files to editable files. Thanks Jim
Hi Jim
Sorry, there are no tools inside of Shark that can do this. Importing a PDF converts it into a image file.
On the CAD blog I show how you can convert an image using Adobe Illustrator's trace tool.
http://blog.punchcad.com But to convert directly into arcs, line, circles you might need a PDF to DWG app.
Edited by user Friday, November 20, 2015 2:19:34 PM(UTC)
Okay Tim thanks, i have downloaded numerous pdf to dwg apps some work great others not so. I now have to decide which one to get Thanks Jim
the PDF format is a meta format which can contain vector data (aka geometry) as well as raster data (aka pixels).
if the PDF contains vectors (which can be evaluated by selecting a dedicated entity instead of a raster blob or simply by zooming in) you can open it in a graphics application as e.g. Adobe Illustrator or the free
Inkscape and save as DWG (Corel may work too).
if the PDF contains pixels a previous
vectorization is required for being usable in e.g. CAx systems... unfortunately a vectorization cannot create exact data (coordinates, angles) by design sothat creating from scratch is often the better/faster way.
Edited by user Thursday, November 26, 2015 8:27:31 AM(UTC)
| Reason: grammar
