Jimbl
#1 Posted : Friday, November 20, 2015 8:16:58 AM(UTC)
Jimbl
I am currently using Shark LT V8, do any of the newer products convert pdf files to editable files.
Thanks Jim
#2 Posted : Friday, November 20, 2015 2:00:58 PM(UTC)
Hi Jim
Sorry, there are no tools inside of Shark that can do this. Importing a PDF converts it into a image file.
On the CAD blog I show how you can convert an image using Adobe Illustrator's trace tool.
http://blog.punchcad.com
But to convert directly into arcs, line, circles you might need a PDF to DWG app.
Edited by user Friday, November 20, 2015 2:19:34 PM(UTC)  | Reason: Not specified
Jimbl
#3 Posted : Friday, November 20, 2015 5:04:21 PM(UTC)
Jimbl
Okay Tim thanks, i have downloaded numerous pdf to dwg apps some work great others not so. I now have to decide which one to get
Thanks Jim
posh.de
#4 Posted : Tuesday, November 24, 2015 9:27:37 AM(UTC)
posh.de
the PDF format is a meta format which can contain vector data (aka geometry) as well as raster data (aka pixels).
if the PDF contains vectors (which can be evaluated by selecting a dedicated entity instead of a raster blob or simply by zooming in) you can open it in a graphics application as e.g. Adobe Illustrator or the free Inkscape and save as DWG (Corel may work too).
if the PDF contains pixels a previous vectorization is required for being usable in e.g. CAx systems... unfortunately a vectorization cannot create exact data (coordinates, angles) by design sothat creating from scratch is often the better/faster way.
Edited by user Thursday, November 26, 2015 8:27:31 AM(UTC)  | Reason: grammar
