2D Drafting
Translate - Option/Copy not working like it used to
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Hi – I recently upgraded from Shark FX 8 to Shark LT 9.
In 8 I used to be able to:
- Select an object
- Select the translate tool
- Manually input the distance (to translate) in the fields at the top
- Hold down OPTION while hitting Return/Enter
- COPY of object translates that distance
Now, in Lt 9, Option only works to copy when you click on the point of origin and then the new location.
Help please.
Here is a screenshot although I don't think it really explains..
(273kb) downloaded 19 time(s). You cannot view/download attachments. Try to login or register.
Someone please help... Anyone have any idea? If I need to articulate I will try.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
The only thing that I can think of, and believe me, this has happened to me plenty of times, I copied or moved an object and it's not visible until I do a 'ZOOM ALL' because it is off the screen. Or I am in the wrong view, and the line is moving towards or away from me, or a decimal point is off. The cntrl-enter works for me on the PC SharkFX9. Larry
Hey thanks a bunch Larry. I'll try cmd+enter or ctrl+enter. Maybe i was missing a step.
2D Drafting
