i installed this program some months ago.
today i need it but i cant use.
when try to start i receive only the error message Error:209.
i was searching for a solution and i found
http://support.encore.co...1934&product_id=3390 this is my code
4V7VT-E7ZYB-36U9G-LFUWH-X9OVV-HPXCJ-7E5O4
please send me a code for reactivation.
thank you in advanced.
Hello
You will need to send your activation code to Encore tech support, using the info from this link. Encore tech support does not monitor the forum.
http://forum.punchcad.co...sts&t=6861#post25277 With SP1, Encore updated the DRM which minimizes the display of this message.
I have the same problem: I get Error 209, I have sent the given code ) to the technical
support and still did not get an answer after 3 days !
Does anybody know how to proceed ?
Holger
Edited by moderator Thursday, January 14, 2016 2:30:29 PM(UTC)
I sent your post to Encore tech support. You may also need to check your junk/spam folder and that you can receive emails from Encore. Tim
