Construction Line- Bug?
Was thanked: 5 time(s) in 3 post(s)
VIACAD Pro 904 b1166
Draw a construction line. Then "Select" the line. Change the "Y" value and hit "Enter". Nothing is moved and the location digit is the same?
How to move the "construction line" then, if not moving it with the mouse.
*When doing the same with a "Line" no problem!
Is this a bug???
Edited by user Tuesday, October 27, 2015 8:08:33 AM(UTC)
Originally Posted by: 3dup VIACAD Pro 904 b1166 Draw a construction line. Then "Select" the line. Change the "Y" value and hit "Enter". Nothing is moved and the location digit is the same? How to move the "construction line" then, if not moving it with the mouse. *When doing the same with a "Line" no problem! Is this a bug???
Looks like this has changed since V9...
For now you can move a construction line in the inspector tab just have to move both endpoints.
OK. I hope there will be a new build faster this time, latest update was about 1,5 year on the way:-((
Thanks for the heads up. This is now fixed in the next beta build 1174. Tim
Nice, it was not you I talking about, when I complain over the release time!
