2D Drafting
How do you split a line and keep both halves? Shark LT9
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Simple question: How do you split a line at any point and keep both lines (without deleting anything)? I know I did it before but now I can't figure it out even after looking in the manual. I know that the TRIM tool deletes a line segment where its intersected by another line... but how do you keep both lines? Thanks!
Thanks: 175 times Was thanked: 158 time(s) in 108 post(s)
Use the "Segment At Location" Tool, same menu bar as "Trim".
Select your line, and then the point where you want to separate the line.
Edited by user Friday, October 23, 2015 3:15:59 AM(UTC)
(73kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Thanks a bunch! I was looking for the word "split" but this makes more sense.
2D Drafting
