JimEddy
#1 Posted : Tuesday, October 13, 2015 10:18:14 AM(UTC)
JimEddy
How can I change the grain direction of different parts in a wood rendering? Are there any videos (I've looked but can't find anything so far)?
#2 Posted : Tuesday, October 13, 2015 11:13:18 AM(UTC)
Hi Jim
It depends on the product and the type of material (image file or procedural wood). Do you have a example file?
Edited by user Tuesday, October 13, 2015 11:15:24 AM(UTC)  | Reason: Not specified
JimEddy
#3 Posted : Thursday, October 15, 2015 7:42:40 AM(UTC)
JimEddy
Here's a small sample file. I'm using the wood from the Render Library. It's a simple wood frame. The grain should go vertically, as it does, on the stiles. The rails should have the grain going horizontally.
Wood Grain Test.vcp (16kb) downloaded 11 time(s).
JimEddy
#4 Posted : Thursday, October 15, 2015 7:45:05 AM(UTC)
JimEddy
I'd also like to be able to make it look more like wood.
L. Banasky
#5 Posted : Thursday, October 15, 2015 12:34:37 PM(UTC)
L. Banasky
The wood grain can be rotated with the advanced render settings in the Inspector.
Right click on the horizontal board, and change the settings in TextureSpace.
Rotate Wood Grain.jpg (93kb) downloaded 25 time(s).
JimEddy
#6 Posted : Thursday, October 15, 2015 2:19:44 PM(UTC)
JimEddy
Thanks. So the X Plane turns the rendering to run along the X axis? Is the Z Plane the default?
#7 Posted : Wednesday, October 28, 2015 10:45:54 PM(UTC)
I made a video today showing some ways to apply and create wood textures.
https://youtu.be/fuRD3R-AdHg
flatpack on 4/1/2016(UTC)
