Rendering & Display
Help - Colored Faces of Solid not being recognized in Keyshot
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Please help.
I am using Shark LT v9. Whenever I change a color of an individual face to apply a different texture or texture direction in Keyshot, Keyshot does NOT recognize these new colors. It still only sees one single color for all faces so I can't properly do things like wood grain.
I've attached these to show what I've checked in the export box.
As you can see in the Keyshot image, I only dragged ONE material to one face and yet even though each face is clearly exported as a different color, the material applied itself to the entire solid.
Edited by user Thursday, October 8, 2015 9:52:11 PM(UTC)
(110kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
This should now be updated in 1172. Attached image is a single solid with mutilple colors by face exported as an OBJ into another app.
Attached is an obj for you to confirm this also works with keyshot.
Edited by user Friday, October 9, 2015 4:23:00 PM(UTC)
dice.zip
(306kb) downloaded 8 time(s). Tim Olson attached the following image(s):
(442kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
I imported a step file with single solid with many face colors and imported as an obj into keyshot.
I then changed the canopy to glass in keyshot.
tim
(819kb) downloaded 17 time(s). You cannot view/download attachments. Try to login or register.
Thanks a lot Tim! But could you please re-save the .obj file as version 3 in KS? I only have 3 unfortunately. Also, approximately what would be the time frame until the 1172 update? :)
>>Also, approximately what would be the time frame until the 1172 update? I'll private email you a link to the 1172 beta today. If you can confirm this updates the issue that would be great. Tim
Originally Posted by: Tim Olson >>Also, approximately what would be the time frame until the 1172 update? I'll private email you a link to the 1172 beta today. If you can confirm this updates the issue that would be great. Tim
Tim, confirmed. The issue is now resolved 100%. Much appreciate your speedy fix!
Rendering & Display
