clarofoto
#1 Posted : Monday, March 23, 2015 9:14:07 AM(UTC)
clarofoto
Hello
I prefer beginning with a bit more layers and the layer "DImension" every time in yellow.
What is the best way for a "default template" (protected file)?
Regards Roger
martinwh99
#2 Posted : Tuesday, September 22, 2015 4:48:42 AM(UTC)
martinwh99
Switzerland
Im also interested is there a way to do This?
Martin Krueger
ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D
#3 Posted : Tuesday, September 22, 2015 7:55:24 AM(UTC)
Create a file with the layers, views, pen styles that you would like at startup. Save the file and:
Rename your saved file as startup.dat and place this file in the following location:
Mac
/Applications/ViaCAD Pro 9.app/Contents/Resources/startup.dat
Win
/Program Files/Punch! Software/ViaCAD Pro 9/startup.dat
Each time the app is launched, it will read this file in first.
Edited by user Tuesday, September 22, 2015 11:32:35 AM(UTC)  | Reason: Not specified
martinwh99
#4 Posted : Tuesday, September 22, 2015 10:46:03 AM(UTC)
martinwh99
Switzerland
Thanks Tim i will try that
Martin Krueger
